Folge dem Video um zu sehen, wie unsere Website als Web-App auf dem Startbildschirm installiert werden kann.
Anmerkung: Diese Funktion ist in einigen Browsern möglicherweise nicht verfügbar.
MAIN HYDRAULIC PUMP All Models R 251.
REMOVE AND REINSTALL
On models equipped with auxiliary pump, drain the system and remove hydraulic lift cover as outlined in paragraph 247 and transmission top cover as in paragraph 175. ...
Transmission TOP COVER All Models
175. REMOVE AND REINSTALL.
On Model MF135, the transmission top cover is integral with the steering gear housing and removal procedure is outlined in paragraph 13. On other models, remove rear hood side panels and battery. Remove the screws se-
curing instrument panel to transmis- sion cover. Raise instrument panel about 1-inch and secure by blocking, then unbolt and lift off the top cover with shift lever attached.
(Tolle Baustelle die du hast !)
